SELECTserver Licensing Landing Page
In case of new SelectServer V9 the response file returned by Bentley after manual log transmittal is a zipped XML file with format .xml.zip. When importing this file into SelectServer it must be supplied as is (MUST NOT BE UNZIPPED), otherwise the process will fail with the error: "HTTP Error 404.13 The request filtering module is configured to deny a request that exceeds the request content length" in case of IIS 7 and higher and with the error "Maximum Request Length Exceeded" in case of IIS 6.0. See the corresponding screenshots below.
If the error still occurs with a zipped response file, please apply the following modified web.config file as a fix.
For IIS 7 and higher:
For IIS 6.0:
