| Product(s): | SELECTserver Gateway | ||
| Version(s): | N/A | ||
| Area: | Installation / Configuration | ||
| Subarea: | Networking |
The Bentley SELECTserver Gateway service fails to start, and messages like the following are found in the SS-Bentley.SelectServer.Gateway.exe.log file located in C:\Program Files\Bentley\SELECTserver\Logs:
02-28-17 09:55:41 DEBUG - Gateway - Bentley SelectServerGateway Starting...
02-28-17 09:55:41 INFO - Common - Misc WebService URL: http://selectserver.bentley.com/bss/ws/Misc.asmx
02-28-17 09:56:03 ERROR - Gateway - Error checking SELECTserver version: Unable to connect to the remote server
02-28-17 09:56:03 INFO - Gateway - Starting license renewal.
02-28-17 09:56:03 INFO - Gateway - License Request for Gateway
02-28-17 09:56:03 INFO - Common - Gateway URL: http://selectserver.bentley.com/bss/ws/GatewayWS.asmx
02-28-17 09:56:24 ERROR - Gateway - Error Attempting to renew license file: Unable to connect to the remote server
02-28-17 09:56:24 ERROR - Gateway - License File Not Found. Gateway can not start without a license.
By default, the Bentley SELECTserver Gateway service is configured to run as the local system user. However, the security policy of the network may prevent the local system user from accessing the Internet. This can pose a problem if the SELECTserver Gateway is configured to use Bentley's hosted SELECTserver on the Internet (i.e. selectserver.bentley.com).
Domain users are more likely to have Internet access than the local system user. To troubleshoot access issues, configure the Bentley SELECTserver Gateway service to run as a domain user with the following instructions:
Best Practice: Specify a domain user with a non-expiring password, usually a service account. Otherwise, the credentials used by the SELECTserver Gateway service will require updates any time the password is changed to keep the service running.
Windows could not start the Bentley SELECTserver Gateway service
| Original Author: | Jeremy Hoesly |
