How to setup MicroStation logging with ProjectWise Explorer Integration TN
Overview:
This is to obtain a debug log for troubleshooting issues with MicroStation and ProjectWise Integration.
Troubleshooting:
Getting the logging:
1. In ProjectWise Explorer  navigate to Tools --> Associations --> Programs
2. In the Program Associations windows click on the Select an association view: drop down and select 'User Associations' (SC1)
SC1
3. Scroll down to MicroStation and expand open and then expand Bentley.MicroStation.Application..... Double click on 'Command Line Argument' in the window type         -debug and click OK (SC2)
SC2
SC3
4. Open the file and a command window will open (SC4) once this command windows dismisses it will create a .txt file that will have the output of what I need.
The file get's created in C:\Users\<USER.NAME>\AppData\Local\Temp file is called msdebug.txt
SC4
