Open the SELECTserver administration site. For our hosted SELECTserver (most common), please use https://selectserver.bentley.com/. For users with a Deployed (in-house) server, please use http://servername/bss/admin where "servername" is the machine name on which SELECTserver is installed.
Open the Reports drop-down menu.
Select the report options accordingly as shown in figure below. For example go to Peak Usage Reports -> Daily Peak Usage.
For more information on reports, select Index from the Help drop-down menu, and navigate to the Reports section as shown in the screenshot below:
For deployed SELECTserver users, copies of the manual are provided below.
For 08.xx.xx.xxx Download
For 09.xx.xx.xxx Download
