The following resources are provided as a reference by Bentley's Technical Support Group.
Video Clips
- Video: Break Linear Feature Command
- Video: Compass Rule Adjustment
- Video: Create a Point and add it to a Survey Chain
- Video: Create new linear feature by adding points
- Video: Creating Horizontal Geometry and Profile from Survey Feature
- Video: Example using VBA Macros to Draw Pipes as 3D when Importing Survey Data
- Video: Adding Linear Template features to Terrain from Survey Fieldbook
- Video: Export Field Data Book
- Video: Importing Civil 3d Field Book (FBK)
- Video: Multiple Survey Settings
- Video: Sample Survey Workflow
- Video: Survey Control Points
- Video: Survey Data to CSV file
- Video: Survey Filters Example
- Video: Importing Trimble JOB files using TrimbleLink
- Video: Create GEOPAK SMD feature and import to OpenRoads Feature Definition
- Video: UpDown Link Code Demonstration
TechNotes
