Error 126 MDL Loader: Unable to load library (DLL or MDL shared library) mcmtb
Error 126.
Product(s) and Version(s):
MicroStation integrated with ProjectWise Explorer
Problem:
When trying to open a design file in an integrated ProjectWise Explorer environment using MicroStation, the following error message is displayed:,
OS could not load C:\PROGRA~1\Bentley\PROJEC~1\bin\v1000\mcmtb.dll, error 126.
The design file opens, however, attribute exchange does not work. The relevant key-ins like titleblock updatedms are not recognized.
The following path must be added to the MicroStation configuration variable of MS_LIBRARY_PATH,
C:\Program Files\Bentley\ProjectWise\bin\v1000
The above directory should be available in the variable of MS_LIBRARY_PATH, by default. However, if the directory is not enlisted, it will cause the above-described issue.
  1. Open any file in MicroStation. Select File> Settings> Configuration> Configuration Variables.
  2. In the ‘Configuration Variables’ dialog that follows, search for the variable,
    MS_LIBRARY_PATH
  3. Click on the Edit button. Change the Edit mode to ‘Append’. In the ‘New Value’ field, enter the following directory,
    Click on OK. This will add the variable to the User Preferences file, which is located in the following directory,
    C:\Users\<username>\AppData\Local\Bentley\MicroStation\10.0.0\prefs
    Restart MicroStation.
