SELECTserver Licensing Landing Page
| Product(s): | SELECTserver Gateway | ||
| Version(s): | 09.01.00.31 | ||
| Area: | Installation / Configuration | ||
| Subarea: | N/A | ||
| Original Author: | Jeremy Hoesly, Bentley Technical Support Group | ||
Some older Bentley products from 2004 and earlier such as MicroStation V8 2004 or MicroStation J cannot talk directly with the latest version of SELECTserver. A backward compatibility environment called the SELECTserver Gateway is provided to license such products. The following support solution shows how to download, install, and configure a SELECTserver Gateway for use with V8 2004 and earlier Bentley products.
The SELECTserver Gateway component should be installed in one of two places:
The component is available free of charge and can be downloaded from Bentley's Software Fulfillment Center.
1. In Brand from dropdown select Bentley Cloud Services and click on Apply.
2. In SELECTserver Gateway click on Get Software.
3. Click on Download according to your system configuration whether it is 32bit or 64 bit.
Perform the following steps to install the SELECTserver Gateway:
Change the LIC files used by your V8 2004 or earlier Bentley products to contain a single line:
SERVER=GatewayName
Replace GatewayName with the computer name that is running your SELECTserver Gateway.
See the wiki "Pointer File Explained for Pre- XM Products" for further information on how to create, name or save the local file.
By default, the Gateway points to a single license pool. It listens to requests on port 3998 and routes them to the license pool configured in the License Management Tool included with the Gateway. However, the Gateway can be configured to listen on multiple ports and route to different license pools.
To do this, first open the SELECTserver.config file located in the SELECTserver installation directory which is usually:
C:\Program Files\Bentley\SELECTserver
Scroll to the very bottom and uncomment the SSConfiguration block so that it looks like the screenshot below:
Specify a default license pool for port 3998. Then write additional <port> lines for each of the license pools. The port numbers themselves are arbitrary, but just ensure that the port numbers you choose are not in use by other programs. Once finished, save changes, and restart the Bentley SELECTserver Gateway service. To use a specific license pool on the client end, specify the port number for the desired license pool in the LIC file.
