| | Applies To | | |
| | Product(s): | SELECTserver | |
| | Version(s): | 09.01.00.31 and earlier | |
| | Environment: | N/A | |
| | Area: | Installation / Configuration | |
| | Subarea: | SQL Management | |
Error or Warning Message
When attempting to connect to a license database in SELECTserver Database Setup, the following error occurs:
The specified connection is invalid
[DBNETLIB][ConnectionOpen (SECCreateCredentials()).]SSL Security error.
Invalid connection string attribute
Explanation
SELECTserver utilizes the TLS 1.0 protocol for database communication. If this protocol is disabled, SELECTserver cannot function properly.
How to Avoid
Please perform the following steps to enable TLS 1.0:
- Open the Windows Start menu, and search for Local Security Policy.
- Select Local Policies > Security Options from the left sidebar, and double-click "System cryptography: Use FIPS compliance algorithms for encryption, hashing, and signing."
- Select the Enabled radio button in the window that appears, and click OK to save changes.
- Close the Local Policy Editor.
- Open Registry Editor, navigate to HKLM\SYSTEM\CurrentControlSet\Control\SecurityProvider\SCHANNEL\Protocols\TLS 1.0\Server, and ensure DisabledByDefault is set to 0 and Enabled set to 1.
- Do the same for HKLM\SYSTEM\CurrentControlSet\Control\SecurityProvider\SCHANNEL\Protocols\TLS 1.0\Client.
