How to create a new corridor feature definition to display the bottom mesh of the corridor model in
Product(s):OpenRoads Designer
Version(s):10.00.00.120+
Area: Corridor Modeling
Original Author:Marcus Blake, Bentley Technical Support Group
Question:
How to create a new corridor feature definition to display the bottom mesh of the corridor model in OpenRoads Designer?
Answer:
Expand the OpenRoads Standards tab and select the Corridor > Final category as shown the image below:
Right-click, select Copy
In the edit-field, change the name to Final w/ Bottom Mesh, Left-click to accept.
Right-click on Final w/ Bottom Mesh and select Properties.
 In the Properties window pane , locate the Display Settings tab, and change the Bottom Mesh Display to True.
 Close the Properties window.
