| Product(s): | OpenRoads Designer Connect Edition | |
| Version(s): | 10.02.00.60 | |
| Area: | Corridor Modelling | |
| Original Author: | Amita Shinde |
This video demonstrates the steps to separate the cut and fill tie for the earthworks in OpenRoads Designer. At present, when you select the cut / fill, the entire element gets selected, however, you can get separate cut and fill lines to be selected on the corridor.
