| Version(s): | 10.00.00.120+ |
| Area: | Corridor Modeling |
| Original Author: | Chris Key, Bentley Technical Support Group |
This video will demonstrate the process of placing a dimension line in an ORD CONNECT Dynamic Cross Section View. There are two locations which will allow placement of the temporary dimension lines. These options are using the Corridor Modeling -- Dynamic Sections -- Show Place Dimension OR right-clicking in the dynamic cross section view and select 'Place Temporary Dimension Line'. The text which displays is relative to the size of the view window. Once through with placing some dimension lines, we demonstrate how to clear/delete the temporary dimensions.
