| Product(s): | ProjectWise Design Integration | ||
| Version(s): | 10.00.03.49 | ||
| Area: | N/A | ||
| Subarea: | N\A |
Last Error 112233 CONNECTION Client could not be accessed- unknown error occurred.
Failed to retrieve a login token from CONNECTION Client.
Might happen when logging into ProjectWise Explorer with Bentley IMS credentials.
Additional troubleshooting steps:
- Verify that the User Account is set to Federated Identity in ProjectWise Administrator
- Uninstall CONNECTION Client
- Navigate to C:\Program Files (x86)\Common Files\Bentley Shared - rename the CONNECTION Client folder
- Reboot the Machine
- Reinstall CONNECTION Client
