| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 10.00.03.44 | ||
| Area: | User Tools | ||
| Original Author: | Mantas Nauseda, Bentley Technical Support Group |
ProjectWise User Tools does not show any Datasources
After investigations it appeared that the users ProjectWise Network had not been defined.
To check if defined or to add:
Please consult your ProjectWise Administrator for Server details, if Test Connection fails please consult you IT in the first instance.
Projectwise datasources do not display in Projectwise Explorer
