ProjectWise Compatibility Matrix
These links are to the ProjectWise Compatibility matrixes in the ProjectWsie Help documentation.
For ProjectWise 2023 and newer, refer to the link below.
https://docs.bentley.com/LiveContent/web/ProjectWise%20Version%20Support%20Matrix%20Guide-v1/en/GUID-85F0E7B4-8D5D-4F4E-95D6-E595F4D39459.html
For versions of ProjectWise Design Integration Connect up to 10.00.13.453, refer to the link below.
https://docs.bentley.com/LiveContent/web/ProjectWise%20Version%20Support%20Matrix%20Guide-v1/en/GUID-2FD73349-D765-45FF-87C2-3FBA66493576.html
