Offline Usage
Once you've already signed in on a machine and have loaded entitlements your machine will revert to the last known entitlements if you do not sign in. In this case if your administrator has not disabled offline mode by requiring sign in (see Entitlement Management Configuration) your application will revert to offline status. You will have a 7 day grace period before you have to sign back in or your application will become disabled.
1. Start the desktop application
2. CONNECTION Client appears
3. Don't Sign in, click X to close and you will see the following message:
4. Click continue and the application status will change to Offline
5. To resolve, sign in
See Also:
License Check Out in Entitlement Management Configuration
Other Language Sources
Deutsch
Italiano
Español
日本語
Polski
