| Version(s): | 10.03.00.43+ |
| Area: | Drawing Production |
| Original Author: | Chuck Lawson, Bentley Systems - Senior Application Engineer |
Problem: After creating a sheet model, some linestyles do not display as they did in the drawing model.
Solution: As demonstrated in the video below, it is recommended to turn OFF the "Scale Linestyles by Reference Scale" toggle in the Sheet Model Seeds.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
YT-FC
