Microsoft Azure AD configuration for WS-Federation
Introduction
This guide provides instructions for setting up Single Sign-on between Microsoft Azure AD and Bentley's Identity Management System (IMS), for your corporate users.
This guide assumes that your Azure AD tenant is properly set up on a SSL /TLS endpoint using HTTPS, and that the authentication address is accessible by your corporate users.
Create the Application in Azure AD
Note: The interface for Azure changed in early 2019, so your Azure interface may look different than the screenshots depicted below.
Choose Single Sign-On and SAML:
 Define the URLs
Define the Claims
You will need to add the country claim, which is not included by default.
 Define the Users and Groups for this application
User Assignment Required?
Alternately, you may add users and groups explicitly.  This can be used to limit access to Bentley users and IT admins if desired.
Copy the federation metadata URL and send it to Bentley
Configure the Branding page (optional)
Troubleshooting:
 If you cannot add an application due to a conflict, you may be able to remove it using PowerShell:
Connect-AzureAD
Get-AzureADApplication -All $true | select DisplayName, IdentifierUris | where IdentifierUris -Contains "https://ims.bentley.com/"
Get-AzureADApplication -Filter "DisplayName eq 'Bentley'"
Remove-AzureADApplication -ObjectId " ????????-???-????-???-????????????"
