Cross Section Components are missing in the Drawing/Sheet Model
Product(s):OpenRoads Designer
Version(s):10.07.00.56+
Area: Drawing Production
Problem:
When I run the Cross Section Named Boundary tool and create Cross Section Drawings, I notice that certain components are missing and not displaying. If I close and reopen, I receive a message "Visible Edges Cache is out of date for one or more attachments Synchronize CVE display now?"
I also noticed that the reference for the Drawing Model has Visible Edges set to Cached.
  1. Go to Files > Settings > Configuration > Configuration Variable.
  2. Edit to MS_REF_VISEDGE_ATTACH_STATE variable to by Dynamic
  3. File > Save Settings.
  4. Close and relaunch ORD
  5. Recreate your cross section Named Boundaries and Cross Section sheets
