| Version(s): | 10.04.00.48+ |
| Area: | Drawing Production |
| Original Author: | Holly Herring, Bentley Technical Support Group |
If I have multiple alignments or corridors in the same file with the same Feature Definition, how do I isolate one or turn off a specific one?
Place each geometry or corridor in its own file and reference them together to a master file. You can turn the view of each reference on/off if you need to isolate them.
