New SELECT Subscriber Benefits
Check out the newly added benefits for SELECT subscribers
With SELECT CONNECT Edition, infrastructure professionals have the services, support, and applications they need to deliver successful projects. CONNECTservices, a new benefit for SELECT subscribers, advances your organization’s digital evolution and helps you to stay connected – to your work, to your information, and to your teams—at any time, and no matter where you are.
CONNECTservices enables:
CONNECTservices are made available through the CONNECT Center, a personalized site for every Bentley user. The CONNECT Center is your essential resource to all your Bentley services and to connect with Bentley colleagues, other Bentley users in your Organization, and other Bentley users around the world. The CONNECT Center is also where you will access all other CONNECT Edition cloud services.
If you are a Connected User and already have a Bentley Profile, you can sign in to access CONNECTservices immediately.
Administrators: Learn how to establish your Organization’s users as Connected Users so that they can access their CONNECTservices benefits.
Users: Learn how to get CONNECTED and begin to use CONNECTservices.
