An administrator from your organization has configured a license alert to display if use of this product will exceed a defined number of licenses simultaneously in use. Two choices are presented:
- Acknowledge: Proceed and open the product, incurring usage in excess of the defined threshold. Such usage may incur a term license which is billed later, so communication with an administrator is recommended prior to proceeding. To find your administrators, please refer to CONNECT Center Overview, specifically the third point in the section titled "CONNECT Center Welcome Banner."
- Cancel and Quit: Close the product immediately. No usage in excess of the defined threshold occurs.
Please see SELECT Subscription Programs for more information about Term Licenses.
Other Language Sources
Deutsch
Español
Français
Italian
日本語
Polski
