Learn More – Pre-activation
You are currently accessing this application in Pre-Activation mode.  You will be able to use the application for the duration of the Pre-Activation grace period.  After that period has expired, you will no longer be able to use the product.  To activate the application, please sign in via the CONNECTION Client.  If the application continues to remain in Pre-Activation mode, contact your Administrator to grant access to this application.
Other Language Sources
Deutsch
Español
Italian
