Video: What is CONNECT Advisor?
Product(s):OpenRoads Designer
Version(s):10.00.00.120+
Area: Corridor Modeling
This video explains CONNECT Advisor.
CONNECT Advisor is a software component/desktop application which provides a unified interface for you to interact with various Bentley content in one location, thereby eliminating the need to browse to various sources individually. CONNECT Advisor boosts productivity as it reduces the time required to access and get information. You get the ability to browse-search-view-interact without having to leave the application that you are working on.
https://youtu.be/ouaOdfJIKH8
