| Product(s): | OpenRoads Designer Connect Edition | |
| Version(s): | 10.02.00.60 | |
| Area: | Sheet Index | |
| Original Author: | Amita Shinde |
This video demonstrates the steps for sheet indexing in OpenRoads Designer. It shows the workflow for creating sheet index for plan, profile and cross sections, using the print organizer to print the sheets from Sheet Index and so on.
