| Version(s): | 10.00.00.120+ |
| Area: | Geometry |
| Original Author: | Holly Herring, Bentley Technical Support Group |
Question:
How do I reverse the direction of the horizontal geometry stationing?
Answer:
Since the version 2018R4 (10.05.00.30) the command 'Transpose Element' has been added under OpenRoads Modeling / Geometry / Horizontal / Modify > Transpose Element
To reverse this direction, follow the steps below:
Prior to the version 2018R4 (10.05.00.30) you can use this workflow:
The station of the horizontal geometry element below is from west to east:
The resulting alignment will be stationed in the desired direction (in this case, east to west).
