SELECTserver Licensing Landing Page
| Product(s): | Bentley Product License Filenames (Nodelocked and SELECTserver) | ||
| Version(s): | V 8.0 and below | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
When licensing a pre-XM application with a standalone Nodelock license file, the license file should be delivered from Bentley with the correct file name. Copy the attachment to the appropriate directory. Once the license file is in place, launch the product and it should start.
If necessary, see below for a list of license file names and locations.
If you are running a pre-XM application with server-based licensing, please refer to Pointer Files Explained for Pre-XM Products, before proceeding.
For Pre-XM applications new than 8.0, refer to License File Names V8 for license file names and locations.
| Product | Nodelocked License Name | Default License Directory | SELECTserver License Name |
| Foundation Products | |||
| MicroStation V8 | msv8.lic | ...\program files\bentley\program\licensing\ | msv8.lic |
| MicroStation/J | msj.lic | ...\bentley\program\licensing\ | msj.lic |
| Bentley Redline | bentleyrdl.lic | ...\program files\bentley\program\licensing\ | bentleyrdl.lic |
| Any Engineering Configuration MicroStation CivilPAK MicroStation GeoGraphics v7.1 MicroStation Modeler v7.1 MicroStation Schematics v7.1 MicroStation TriForma v7.1 |
| MicroStation PowerDraft v8 | draftv8.lic | ...\bentley\program\licensing\ | draftv8.lic |
| MicroStation PowerDraft v7.1 | draft70.lic | ...\bentley\program\licensing\ | Not Supported |
| MicroStation PowerScope v7.1 | scope70.lic | ...\bentley\program\licensing\ | Not Supported |
| Project Review, an EEM Access client | prjreview70.lic | ...\bentley\program\licensing\ | prjreview70.lic |
| ProjectWise | |||
| ProjectWise Document Publisher | pwdp.lic | ..\program files\allaire\jrun\servlets | Not Supported |
| ProjectWise MarkUpManager License (See TechNote 8339) | pwmkp.lic | ..\program files\bentley\pwserver\license | Not Supported |
| ProjectWise Server License | pw.lic | ..\program files\bentley\pwserver\license | Not Supported |
| Viecon | |||
| Viecon.interchange | interchange.lic | ...\bentley\program\licensing\ | interchange.lic |
| Viecon Publisher | n/a | ..\bentley\program\VieconPublisher | vp.lic (must use SELECTserver v7.3) |
| Imaging and Conversion | |||
| Bentley Descartes v8.0 | dcartes.lic | ...\bentley\program\licensing\ | dcartes.lic |
| MicroStation Descartes v7.0 | dcartes.lic | ...\bentley\program\licensing\ | Not Supported |
| MicroStation Descartes v7.1 (or higher) | dcartes.lic | ...\bentley\program\licensing\ | dcartes.lic |
| Bentley I/RAS B v8.0 | irasb.lic | ...\bentley\program\licensing\ | irasb.lic |
| MicroStation I/RAS B | irasb.lic | ...\bentley\program\licensing\ | irasb.lic |
| MicroStation ReproGraphics v7.0 | repro.lic | ...\bentley\program\licensing\ | Not Supported |
| MicroStation ReproGraphics v7.1 | repro.lic | ...\bentley\program\licensing\ | repro.lic |
| Geoengineering Products | |||
| Bentley Water | bw.lic | ...\bentley\program\licensing\ | bw.lic |
| Bentley Waste Water | bww.lic | ...\bentley\program\licensing\ | bww.lic |
| Bentley PowerMap | powermap.lic | ...\bentley\program\licensing\ | powermap.lic |
| Bentley PowerMap Field | powermapfield.lic | ...\bentley\program\licensing\ | powermapfield.lic |
| GeoSELECTools | geoseltools.lic | ...\bentley\program\licensing\ | msj.lic |
| GeoXpressions | geoxpressions.lic | ...\bentley\program\licensing\ | geoexpressions.lic |
| MicroStation GeoCoordinator | gcoord.lic | ...\bentley\program\licensing\ | msj.lic |
| MicroStation GeoDynSeg | dynseg.lic | ...\bentley\program\licensing\ | dynseg.lic |
| MicroStation GeoAddress | msga.lic | ...\bentley\program\licensing\ | msga.lic |
| MicroStation GeoExchange | msj.lic (v7.1) geoexch.lic (v7.0) |
| MicroStation GeoGraphics | msgeo.lic | ...\bentley\program\licensing\ | msj.lic (uses an EC license) |
| MicroStation GeoOutlook v7.1 | geoolk70.lic | ...\bentley\program\licensing\ | Not Supported |
| MicroStation GeoParcel | msgp.lic | ...\bentley\program\licensing\ | msj.lic |
| MicroStation GeoTerrain | geopakgt.lic | ...\bentley\program\licensing\ | Not Supported |
| MicroStation GeoWasteWater | msgeoww.lic | ...\bentley\program\licensing\ | msj.lic |
| MicroStation GeoWater | msgeow.lic | ...\bentley\program\licensing\ | msj.lic |
| MicroStation Telco | msutelco.lic | ...\bentley\program\licensing\ | Not Supported |
| Building & Plant Engineering Products | |||
| Architecture for MicroStation TriForma | architecture.lic | ...\bentley\program\licensing\ | msj.lic |
| Electrical Elementary Diagrams | eed.lic | ...\bentley\program\licensing\ | eed.lic |
| Equipment Modeler | tfeqmod.lic | ...\bentley\program\licensing\ | tfeqmod.lic |
| HVAC for MicroStation TriForma | hvac.lic | ...\bentley\program\licensing\ | msj.lic |
| Interference Manager | Ifmeng.lic | ...\bentley\program\licensing\ | Ifmeng.lic |
| IsoExtractor | isoextps.lic | ...\bentley\program\licensing\ | isoextps.lic |
| L/ISO | liso.lic | ...\bentley\program\licensing\ | liso.lic |
| MicroStation Landscape | msla.lic | ...\bentley\program\licensing\ | msla.lic |
| MicroStation TriForma v7 | triforma.lic | ...\bentley\program\licensing\ | msj.lic (uses an EC license) |
| Personal ISOGEN | pisogen.lic | ...\bentley\program\licensing\ | pisogen.lic |
| PlantSpace Instrumentation | psinst.lic | ...\bentley\program\licensing\ | psinst.lic |
| PlantSpace P&ID | msj.lic [Note: The future v7.1.4 release will use pspid.lic] |
...\bentley\program\licensing\ | msj.lic (cut and paste P&ID license info into msj.lic) [Note: The future v7.1.4 release will use pspid.lic] |
| PlantSpace Piping 2004 Edtion & Bentley PlantSpace AutoIsogen | bentleypiping.lic | ...\bentley\program\licensing\ | bentleypiping.lic |
| PlantSpace Piping Module | pspiping.lic | ...\bentley\program\licensing\ | pspiping.lic |
| PlantSpace Piping Module (DIN) | pspipingdin.lic | ...\bentley\program\licensing\ | pspipingdin.lic |
| PlantSpace SupportModeler | pssupmod.lic | ...\bentley\program\licensing\ | pssupmod.lic |
| PowerArchitect | pwrarch.lic | ...\bentley\program\licensing\ | msj.lic |
| Raceways | tfrace.lic | ...\bentley\program\licensing\ | tfrace.lic |
| Bentley Structural | structural.lic | ...\bentley\program\licensing\ | structural.lic |
| Structural for MicroStation TriForma | stf.lic | ...\bentley\program\licensing\ | stf.lic |
| SupportModeler for PDS | pssupmodpds.lic | ...\bentley\program\licensing\ | pssupmodpds.lic |
| AutoPLANT Products | |||
| 2D Piping 2.01, 3.0, 8.5 | 2dpiping.lic | ...\program files\bentley\program\licensing\ | 2dpiping.lic |
| AutoISOGEN PLUS 2.01, 3.0, 8.5 | autoisogenpl.lic | ...\program files\bentley\program\licensing\ | Not supported on SELECTserver |
| AutoPLANT Raceways 8.5 | 3delect.lic | ...\program files\bentley\program\licensing\ | 3delect.lic |
| AutoPLANT Navigator 16.00 | plvision.lic | ...\program files\bentley\program\licensing\ | Not supported on SELECTserver |
| AutoPIPE Plus 6.3 | autopipepl.lic | ...\program files\bentley\program\licensing\ | autopipepl.lic |
| AutoPIPE 6.3 | autopipe.lic | ...\bentley\program\licensing\ | autopipe.lic |
| AutoPIPE Standard 6.2 | Not Supported | ***** | Not Supported |
| AutoPIPE KHK2 6.3 | autopipekhk2.lic | ...\bentley\program\licensing\ | autopipekhk2.lic |
| Data Manager 16.0, 8.1 | datamanager.lic | ...\program files\bentley\program\licensing\ | datamanager.lic |
| Datasheets 16.00, 8.1 | datasheets.lic | ...\program files\bentley\program\licensing\ | datasheets.lic |
| Drawing Flattener 3.0, 8.5 | drawingflattener.lic | ...\program files\bentley\program\licensing\ | drawingflattener.lic |
| Electrical 3.0 | 3delect.lic | ...\program files\bentley\program\licensing\ | 3delect.lic |
| Equipment 1.51, 2.00, 2.01 | apequipment.lic | ...\program files\bentley\program\licensing\ | apequipment.lic |
| Equipment 3.0, 8.5 | equipment.lic | ...\program files\bentley\program\licensing\ | equipment.lic |
| Explorer 6.2, 7.3, 8.5 | apexplorer.lic | ...\program files\bentley\program\licensing\ | apexplorer.lic |
| Hookups 16.0, 8.1 | hookups.lic | ...\program files\bentley\program\licensing\ | hookups.lic |
| Instrumentation 16.0, 8.1 | instrumentation.lic | ...\program files\bentley\program\licensing\ | instrumentation.lic |
| Interference Detection 6.1, 6.2, 7.3, 8.5 | interference.lic | ...\program files\bentley\program\licensing\ | interference.lic |
| ISOGEN Server 2.0, 3.0 | Not supported | ***** | Not Supported on SELECTserver |
| Isometrics 1.51, 2.00, 2.01, 3.0, 8.5 | isometrics.lic | ...\program files\bentley\program\licensing\ | isometrics.lic |
| Multi-Steel 2D 15.00 | multi2d.lic | ...\program files\bentley\program\licensing\ | multi2d.lic |
| Multi-Steel 3D 15.00 | multi3d.lic | ...\program files\bentley\program\licensing\ | multi3d.lic |
| Multi-Steel Modeler 15.00 | multimod.lic | ...\program files\bentley\program\licensing | multimod.lic |
| NWD Export | NWDexport.lic | ...\program files\bentley\program\licensing | NWDexport.lic |
| Photorealism | Photorealism.lic | ...\program files\bentley\program\licensing | Photorealism.lic |
| Piping 1.51, 2.00, 2.01 | appiping.lic | ...\program files\bentley\program\licensing\ | appiping.lic |
| Piping 3.0, 8.5 | piping.lic | ...\program files\bentley\program\licensing\ | piping.lic |
| Piping 8.6 | bentleypiping.lic | ...\program files\bentley\program\licensing\ | bentleypiping.lic |
| P&ID 16.0 | appid.lic | ...\program files\bentley\program\licensing\ | appid.lic |
| P&ID 8.1 | pid.lic | ...\program files\bentley\program\licensing\ | pid.lic |
| P&ID Conversion Toolkit 16.00 | pidconvert.lic | ...\program files\bentley\program\licensing\ | pidconvert.lic |
| P&ID Converter 8.1 | pidconvert.lic | ...\program files\bentley\program\licensing\ | pidconvert.lic |
| AutoPLANT Navigator 16.0 | plvision.lic | ...\program files\bentley\program\licensing\ | plvision.lic |
| PlantFlow 6.0 | plantflow.lic | ...\program files\bentley\program\licensing\ | plantflow.lic |
| PlantFLOW Plus 6.0 | plantflowpl.lic | ...\bentley\program\licensing\ | plantflowpl.lic |
| Project Server 3.0 | projserv.lic | ...\program files\bentley\program\licensing\ | projserv.lic |
| Structural Modeler 16.0, 16.2, 8.5 | strucmodeler.lic | ...\program files\bentley\program\licensing\ | strucmodeler.lic |
| Structural 3D 16.0 | strucengineer.lic | ...\program files\bentley\program\licensing\ | strucengineer.lic |
| Structural Engineering 16.2, 8.5 | strucengineer.lic | ...\program files\entley\program\licensing\ | strucengineer.lic |
| Structural 3D w/NC 16.0 | strucdetailer.lic | ...\program files\entley\program\licensing\ | strucdetailer.lic |
| Structural Detailer 16.2, 8.5 | strucdetailer.lic | ...\program files\entley\program\licensing\ | strucdetailer.lic |
| Vision | Plvision.lic | ...\program files\entley\program\licensing\ | Plvision.lic |
| WinNOZL KHK 3.0 | winkhk.lic | ...\program files\bentley\program\licensing\ | winkhk.lic |
| WinNOZL WRC107 3.0 | winn107.lic | ...\program files\bentley\program\licensing\ | winn107.lic |
| WinNOZL WRC297 3.0 | winn297.lic | ...\program files\bentley\program\licensing\ | winn297.lic |
| WinNOZL API650 3.0 | winnapi.lic | ...\program files\bentley\program\licensing\ | winnapi.lic |
| WinNOZL PD5500 3.0 | winpd55.lic | ...\program files\bentley\program\licensing\ | winpd55.lic |
| Integration and Simulation products | |||
| Dynamic Animator | dynanimator.lic | ...\bentley\program\licensing\ | dynanimator.lic |
| Enterprise Navigator | entnav.lic | ...\bentley\program\licensing\ | entnav.lic |
| ModelServer Integrator | msint.lic | ...\bentley\program\licensing\ | msint.lic |
| Schedule Simulator | schsim.lic | ...\bentley\program\licensing\ | schsim.lic |
| Civil Products | |||
| InRail | selectcad.lic | ...\bentley\selectcad\licensing\ | selectcad.lic |
InRoads v8.3 |
bentleycivil.lic | ...\program files\bentley\civil\licensing\ | bentleycivil.lic |
| InRoads v8.2 | selectcad.lic | ...\bentley\selectcad\licensing\ | selectcad.lic |
| InRoads Bridge | selectcad.lic | ...\bentley\selectcad\licensing\ | selectcad.lic |
| InRoads Construction | selectcad.lic | ...\bentley\selectcad\licensing\ | selectcad.lic |
| InRoads Site | selectcad.lic | ...\bentley\selectcad\licensing\ | selectcad.lic |
| InRoads Storm & Sanitary | selectcad.lic | ...\bentley\selectcad\licensing\ | selectcad.lic |
| InRoads Survey | selectcad.lic | ...\bentley\selectcad\licensing\ | selectcad.lic |
| MicroStation CivilPAK | geopakcp.lic or msj.lic (with EC) | ...\bentley\program\licensing\ | msj.lic or msv8.lic (with EC) |
| GEOPAK Civil Suite | geopak.lic | ...\bentley\program\licensing\ | msv8.lic or geopak.lic & MS node .lic |
| GEOPAK Site | geopak.lic | ...\bentley\program\licensing\ | msv8.lic or geopak.lic & MS node .lic |
| GEOPAK Survey | geopak.lic | ...\bentley\program\licensing\ | msv8.lic or geopak.lic & MS node .lic |
| GEOPAK Bridge | geopak.lic | ...\bentley\program\licensing\ | msv8.lic or geopak.lic & MS node .lic |
| GEOPAK Rebar | geopak.lic | ...\bentley\program\licensing\ | msv8.lic or geopak.lic & MS node .lic |
| Plotting Products | |||
| InterPlot Client | ipcli.lic | ...\Program Files\Common Files\InterPlot\Licensing\ | ipcli.lic |
| InterPlot Driver Pack | ipdrvpck.lic | ...\Program Files\Common Files\InterPlot\Licensing\ | Not Supported |
| InterPlot Mid-Volume Driver Pack | ipmvdpk.lic | ...\Program Files\Common Files\InterPlot\Licensing\ | Not Supported |
| InterPlot Professional | ippro.lic | ...\Program Files\Common Files\InterPlot\Licensing\ | Not Supported |
| InterPlot Raster Offline Driver Pack | ipoffdrv.lic | ...\Program Files\Common Files\InterPlot\Licensing\ | Not Supported |
| InterPlot Server | ipsrv.lic | ...\Program Files\Common Files\InterPlot\Licensing\ | Not Supported |
| InterPlot Digital Print Room Workgroup | ipdprwg.lic | ...\Program Files\Common Files\InterPlot\Licensing\ | Not Supported |
| Digital Print Room Enterprise (12 limit) | ipdpr12.lic | ...\Program Files\Common Files\InterPlot\Licensing\ | Not Supported |
| Digital Print Room Enterprise (unlimited) | ipdprunl.lic | ...\Program Files\Common Files\InterPlot\Licensing\ | Not Supported |
License File Names for Previous Versions
| MicroStation SE | ustation.lic |
| MicroStation 95 | ms95.lic |
| MicroStation V5 | ms50.lic |
| MicroStation ERPIntegrator/S | mssap.lic |
| MicroStation ERPScope/S | pscsap.lic |
| MicroStation GeoAddress | sdadr.lic |
| MicroStation GeoOutlook v5.x | geooutlk.lic |
| MicroStation Image Manager for MicroStation SE | usim.lic |
| MicroStation MasterPiece (previous to MicroStation SE) | raytrace.lic |
| MicroStation Modeler (previous to MicroStation/J) | modeler.lic |
| MicroStation Opti SE | optise.lic |
| MicroStation PowerDraft v5.6 | msdraft.lic |
| MicroStation PowerScope v5.5 | msview.lic |
| MicroStation TeamMate | teammate.lic |
| MicroStation TriForma (previous to MicroStation/J) | tf55.lic |
| ModelServer Imager | msiserver.lic |
| ModelServer TeamMate Document Publisher | tmhe.lic |
| ProjectWise MarkUpManager License | mkpmgr.lic |
| ProjectWise Server License | mst.lic |
