SELECTserver Licensing Landing Page
This Technote provides steps to take when first utilizing Bentley Products while they are unlicensed and in Trial Mode (Evaluation Mode).
Please Note: If you have received an Evaluation License from your Account Manager at Bentley, activate the product following [[8585|these instructions]].
Also, Bentley "Trial Versions" are fully functional pieces of software that will run for a period of time without a valid License.
For Further Details on Trial Mode vs. Evaluation Mode [[8587|Click Here]].
Once you have downloaded and installed the software, launch the application. You may be put straight into the “Product Activation Wizard,” If the Product Activation Wizard does not prompt upon launching the application, you can activate using the License Mangement Tool.
Select the "Evaluation Only" option shown in Figure 1.1
Figure 1.1
After you have selected "Evaluation Only", Click Next (Figure 1.2)
Figure 1.2
Following, you will receive a confirmation message and can select CLOSE (Figure 1.3). The product will now run in the Demo/Trial mode.
Figure 1.3
Additional Links
[[About Trust Licensing]]
Bentley Homepage
Bentley Products
Product TechNotes and FAQs
Bentley SELECT Licensing Program Eligibility
