| Version(s): | 10.00.00.120+ |
| Area: | Corridor Creation & Manipulation |
| Original Author: | Holly Herring, Bentley Technical Support Group |
If you apply the same template to 2 corridors in the same dgn and adjust the template for one corridor, does it adjust the template for the other as well?
You can edit templates either in the file or in the template library. If you do it in the file, it will only be that corridor template that is edited. If you do it in the library, you can update all the corridors using that template.
