 | Applies To  |  |  |
 | Product(s): | License Management Tool |  |
 | Version(s): | System.Data.DataRowView |  |
 | Environment:  | N\A |  |
 | Area:  | License Management |  |
 | Subarea:  | N\A |  |
 | Original Author: | Anders OMahony, Bentley Technical Support Group |  |
Problem Description
Every time I start my Bentley Product I am asked to activate the application.
This problem may arise if you do not have the access rights to write the Activation Key to the computer registries or if you forgot to install the Bentley application as Administrator.
Steps to Resolve
The first troubleshooting step would be to check and see if you can run LicenseTool.exe as Administrator.
Go to your programs folder ex. C:\Program Files (x86)\Bentley\PowerDraftV8i\PowerDraft, find LicenseTool.exe > Right Click on the file and Select Run As Administrator.
Now Activate your Bentley Application from the LicenseTool.exe as you would normally. See link below:
The Activation Key should now have been written correctly to the computer registry > Restart the Bentley application and see if you are prompted to Activate the application again. If not the Activation has been successful.
Should you not have the desired Administrator access please contact your in house IT administrator.
If you are still having trouble activating a Bentley application after trying the above, please contact Bentley Technical Support and raise a Service Request or create a new post here on Bentley Communities.
Other Language Sources
Deutsch
