| Product(s): | CONNECTION Client | ||
| Version(s): | pre 10.00.04.17 | ||
| Area: | Access | ||
| Subarea: | N\A |
I can not login to "CONNECTION Client".
Following error message appears:
Connection Faliure
User failed to login
System updates were put into place and the CONNECTION Client versions 10.00.03.xx and older no longer work with those system changes.
Please install the latest version of the CONNECTION Client. Please see How to Download the CONNECTION Client and How to install the CONNECTION Client for step by step instructions.
Bentley Connect - didn't update by February 6th
Unable to sign in Community Client
German: CONNECTION Client: "Benutzer konnte sich nicht anmelden"
http://communities.bentley.com/communities/other_communities/sign-in_assistance_and_web_services/w/wiki/27597.how-to-install-the-connection-client
