Federated user cannot sign in
Product(s):CONNECTION Client
Area:IMS
Problem Description
A federated user can sign into ims.bentley.com but is unable to sign into CONNECTION Client. CONNECTION Client either spins indefinitely while attempting to connect or displays a "failure to connect" message.
Steps to Resolve
Ensure the affected user's contact record in the identity provider (e.g. Active Directory) has a country set. For Active Directory, this is located on the Address tab. A blank country code will prevent CONNECTION Client from signing in.
Other Language Sources
Deutsch
