Product(s): | GEOPAK |
Version(s): | 08.11.09+ |
Area: | General |
Original Author: | Bentley Technical Support Group, Matthew Lynn |
Problem:
When I select the Print and Print to File button, nothing happens.
The issue could be that the config variable MS_PLTFILES is undefined and pointing to a system variable on PW folder that doesn’t exist.
Make sure that MS_PLTFILES is defined so that it would be opened to the proper folder.
