| Version(s): | 10.08.01.33+ |
| Area: | Drawing Production |
How can I turn ON/OFF a level and have the change reflected to all my cross section sheets? By defining the configuration variable "MS_LEVEL_DO_NOT_OVERRIDE_DESIGN_LEVELS_IN_SHEET = 1", any levels that are turned ON/OFF in the 3D Model will also be turned ON/OFF in the cross section drawing and sheet models.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the full screen button (rightmost button at bottom of video).
