| Version(s): | 10.00.00.120+ |
| Area: | Subsurface Utilities |
| Original Author: | Marcus Blake, Bentley Technical Support Group |
Question:
Under Subsurface Utilities>Tools >General Tools > Utility Conflicts, I have selected features in the "Check These Features" and "Against These Features" boxes, why is the "Allow Soft Conflict" option disabled? See screen capture below for illustration.
Answer:
Select a feature in the "Check These Features" dialog box. This will enable the "Allow Soft Conflict" option to be selected and used.
