| Product(s): | Open Roads Designer |
| Version(s): | 10.00.00+ |
| Area: | Geometry |
Question:
I am getting a red circle X warning "Invalid Element. Unable to solve rule. Please correct element construction", but I can not find the element to remove it. How do I delete the invalid element.
Answer:
1.) Select the red circle warning glyph, and open the Properties dialog
2.) Change the level of this element to a 'temp_level' (or any empty level)
3.) Open the key-in dialog and run the following key-in which will delete all elements on the specified level: LEVEL ELEMENT DELETE temp_level (replace 'temp_level" with the level used in step 2 above)
