| Version(s): | 10.00.00.00+ |
| Area: | Subsurface Utility Design and Analysis |
This video demonstrates a process for applying a circular template as a tunneling/boring template for subsurface conduits where a typical trenching excavation is not adequate for deep pipe installation. It utilizes the Trenching Template assigned to the Feature Definition to apply a template to the extrusion path of a conduit.
