| Version(s): | 10.00.00.00+ |
| Area: | Subsurface Utility Design and Analysis |
This video will demonstrate a process of adding a parametric constraint to a corridor created from a trenching template. This example edits a circular component radius label to change the template component from a 2' radius circle to a 4' radius circle. This same process can be applied to any corridor to edit a parametric constraint label.
