SELECTserver Licensing Landing Page
| Product(s): | SELECTserver | ||
| Version(s): | N\A | ||
| Area: | N/A | ||
| Subarea: | N\A |
When trying to read a response file larger than 7.93 MB on the Deployed Server, the following message appears:
404 - File or directory not found
There may also be errors like:
The Deployed License server is configured to accept Manual Response Files up to 7.93 MB in size. This limit was sufficient for years.
As the product definitions contained in this file have grouwn with new products, the size of the threshold is approaching. The long-term solution is a web.config file configured for manual response files up to 18 MB in size.
To take over, download the file web.config from the following link: Web.Config.Zip
Note:
To download you must be logged in to the Bentley Communities.
Unzip the file
Save the file in your SELECTserver folder, by default that would be at C:\Program Files\Bentley\SELECTserver
Subsequently, the reading of the Response File should be possible.
If not, please reset the webserver and try again:
Reset the webserver IIS
https://communities.bentley.com/products/licensing/m/licensing_gallery/272959
