CONNECTION Client not Found
The CONNECTION Client is required in order to sign into your application. You can download the CONNECTION Client from the Fulfillment Center and the Bentley Resources page.
Please refer to the Download Options article for more details.
NOTE:
You will need Administrative rights to complete the installation - for details, see: CONNECTION Client update fails or causes sign in issues if user doesn't have local admin rights
Download Options
Other Language Sources
Deutsch
Español
Italian
Nederlands
Polish
