| Product(s): | Connection Client |
| Version(s): | 11.xx |
| Area: | Access |
Unable to sign in to the CONNECTION Client 11.x or newer version on Windows Server 12 machine.
You are presented with the following error:
Connection Client supports Windows Server 2012 R2, however, Windows Server 2012 predates Microsoft Edge, so you may need to install Microsoft Edge on the server. You can also downgrade to CC 11.00.01.109 or earlier which utilizes Internet Explorer instead.
To download the Microsoft Edge Click Here.
Other Language Sources
