| Product(s): | OpenRoads Designer | ||
| Version(s): | 10.09.00.91 | ||
| Area: | N/A | ||
| Subarea: | N\A |
When selecting a catchment area and choosing Utility Properties from the pop-up menu, nothing happens.
Launch the Utility Properties in the alternative way:
This issue will be fixed in an upcoming OpenRoads Designer version.
