Product(s): | OpenRoads Designer | ||
Version(s): | 10.08.00.88 | ||
Environment: | N\A | ||
Area: | N/A | ||
Subarea: | N\A |
In OpenRoads Designer a scenario with a physical alternative called "existing conditions" will have a different layout of nodes and links than the scenario with the physical alternative for "proposed conditions". If both are displayed at the same time, it is a mess - really impossible to work with. How does this work in OpenRoads Designer? Elements can be set as either active or inactive in OpenRoads, but how does this affect their display? Is there a way to turn off display of "inactive" elements?
Use different feature definitions for the alternative layouts of nodes and links and then turn the given feature definitions on and off in the Explorer
Video: Introduction to Features and Feature Definitions
