| Product(s): | OpenRoads Designer | ||
| Version(s): | 10.08.00.88 | ||
| Area: | N/A | ||
| Subarea: | N\A |
When opening a DGN, as soon as it loads it closes right away.
We are not able to do anything with the file.
File corruption or civil schema incompatibility in the file references is causing the problem.
Open the file on a different PC where it cannot access the problematic references and detach them.
Recovering Corrupt DGN And DWG Files
