"Error reading the Feature XML File" in the Features XML To/From Excel
 Product(s):OpenRoads Designer
 Version(s):N\A
 Environment:N\A
 Area:N/A
 Subarea:N\A
When trying to open an exported XML file with feature definitions in the "Features XML To/From Excel" tool, a following error message is shown:
"Error reading the Feature XML File: There is an error in XML document (xx, xxx)"
Use dots as deliminators instead of commas in the feature definitions.
Also bear in mind the following limitations of the features xml tool:
Migration Utilites
