| Version(s): | 10.08+ |
| Area: | Survey |
The following variable has changed
CIVIL_SURVEY_RETAIN_SURVEY_ON_COPY
to
CIVIL_SURVEY_RETAIN_SURVEY_DATA_ON_COPY
If you set the value to '1' then when ever you copy a Survey point of Survey Linear it will maintain those as survey items. Otherwise if it is not set then they are copied as line strings or points and the survey data is not maintained.
