| Product(s): | Bentley Licensing Tool |
"Disabled by Policy" on Product Status tab or "DisabledByPolicy" on Entitlements tab
The status usually means a local copy of the license has exceeded its 7-day lifespan. The status can also occur when outstanding usage data has not been transmitted to Bentley in several days.
Perform the following steps to transmit any outstanding usage and retrieve a current license file:
Any DisabledByPolicy status messages on the Entitlements tab should change. Note that values on the Product Status tab will not change until a product is opened again.
Other Language Sources
