| Version(s): | 10.09.00.91+ |
| Area | Platform |
| Original Author: | Ja'Shon Arrington. Technical Support Group |
Question:
I cannot get the north arrow to orient true north automatically, with respect to each rotated plan sheet. What is the workflow to get the north arrow to auto-rotate?
Answer:
In order for the north arrow cell to auto-rotate, you must make sure that the cell type is set to graphic. It will not auto-rotate if the cell type is set to point.
