Once you have signed into the CONNECT Portal using your Bentley CONNECT account, select your project from the Recent Projects tile, or select the View More Projects icon to see a list of all available projects.
2. When you select your project, the Project Portal opens. Under the ProjectWise 365 Services section, select the Share tile.
