Click on the filter icon to filter catalogs or components in your catalogs.
The filters are continually updated and provide a way to quickly filter by Region.
The filters are continually updated and provide a way to quickly filter the components in your catalog by categories, manufacturers, applications and states by clicking on any filter value
Selecting Components
To select a component simply click on it. To select multiple component hold down the <CTRL> key while clicking components. You can remove and edit multiple components.
Searching
To search for specific components simply begin typing in the search control. Search results will begin to appear using component names, properties and tags.
Hitting the Enter Key or selecting one of the results returned in the search will filter the list and apply a search tag. You can remove the search by removing the applied tag.
To remove a component from a catalog, select the component and click the Remove component button.
The Remove component dialog will appear, Click Confirm to complete the removal process, Click Cancel to cancel the process.
Viewing Component Properties
To view a Component’s properties, select a component then click the Properties button.
