Component Details Page
You can now view a dedicated, detailed page of information about any component simply by double clicking on the component or by right clicking on the menu button on the component’s tile.
Component Properties
You can now view properties for each variation included in a component’s design file for parametric .dgn and .rfa file types
Component Files and Links
You can now manage reference files and links as well as download files and open links.
Manage Catalogs
You can now manage catalogs and can now add multiple catalogs to a single component.
Simply click the Add Catalog button then select additional catalogs to be added to the current component. Clicking Confirm will finish the process, Cancel will Cancel the process.
Manage Tags
You can now manage tags and add new or delete existing tags from the current component.
Add Images
You can now add additional images to the current component by clicking the Manage Images button next to the current thumbnail. This will launch the Image Gallery Manager dialog.
Adding a new Image
Click on the Add Image tile to select a new image to be added to the current image set.
Select a valid image file then click the Open button to begin uploading the image to the Image Set.
Your new image will show up in the image gallery and you can navigate between images by clicking the left and right arrow buttons.
